Do i need upgrade?
Do i need upgrade?
Post  BL8M@sT3R on Fri Dec 10, 2010 7:27 pm
Hi guys, i'm using 100mbps starhub connection and also like to know bout router.
I'm using *Linksys (WRT54G) router coz of my sibling using the net too, but my comp
doesn't use wireless it connect direct to the *router with lan cable.
I just want to know does my speed connection affect coz of the router?
Coz my router is wireless G (2.4Ghz).
or i need to upgrade?
BL8M@sT3R
View user profile
Re: Do i need upgrade?
Post  Losty on Sat Dec 11, 2010 11:08 am
I am not so good with network but here goes nothing.
1. I am still using 6mpbs from Singnet and the speed only affects download speed as much and even then, its bottlenecked by your ISP international download speed which is max 25mbps i think.
2. Your LAN connection should either be 100mbps or 1000mbps which i believe is the former so therefore there is no issue. Your router should be a 54mbps router (i think, not sure there) which is enough for gaming.
3. Your connection speed will be affected greatly if someone uses the same connection for downloading. You wont see much difference even if your sis watches youtube. Multiple connections on the same network may cause lag as well, meaning if your 3-5 wireless connections on the same network you use to play games.
Hope it helps. Correct me if am wrong.
Losty
View user profile
Post  Zerofr@G! on Sat Dec 11, 2010 11:20 am
Wow if it's a 100MBps connection then it should not be an issue with your ISP. I am only on 10MBps Singnet. You should try upgrading your PC! Smile
Zerofr@G!
View user profile http://uosg.guildealliance.com
Post  BL8M@sT3R on Sat Dec 11, 2010 2:55 pm
orite thks guys!! think nid to upgrade my pc but no money:((
BL8M@sT3R
View user profile
Post  Sponsored content
- Similar topics
